dana 60 high steer *clearance question*pic
Discussion in 'The Garage' started by poorboy1, Sep 8, 2005.
  1. poorboy1
    poorboy1 Registered Member
    May 26, 2004
    56
    Newberg,OR
    Does anyone run crossover highsteer on a dana 60 with only 4" suspension lift? I just put mine on and even removed the crossmember under the harmonic balancer for room and it appears that you could hit the oil pan under extreme articulation. Just wondering if I'm wasting my time with the 4" lift.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    seen it done plenty of times. Sounds like you are way over flexing your springs if you are getting that close to the oil pan. If your springs are going negative(like the stock springs are normally arched) that is too far and will wear out your springs pretty quick.
  3. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    im with sled dog. it sounds like u need bumpstops
  4. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    4" spring with high steer crossover is my setup. Works fine....lot of pics in my gallery.
    It's a 1st Gen, so that may not be a 100% guarantee for my later K5 brothers.
    :wink1:
  5. poorboy1
    May 26, 2004
    56
    Newberg,OR
    I usually flex the spring backwards, havent ruined them yet but I'm sure some day I will. I still have factory bump stops and I use them when jumping or flexing hard.
    [​IMG][/IMG]
    The hi steer came off an early 70's chevy and now its on a 75. I will just finish up the new eng crossmember then hit the RTI ramp, see what hit's. Might just have to go to 6" lift(I dont wanna loose the flex though) or bite the bullet and start a coilover front end.
  6. poorboy1
    May 26, 2004
    56
    Newberg,OR
    I checked yur pics and you got WAY more clearance then me. You got a lil different crossover but your spring to frame clearance looks greater too.
    I have removed the crossmember since this pic but you can get an idea of how close it was.
  7. poorboy1
    May 26, 2004
    56
    Newberg,OR
    Has anyone tried to unhook the crossover arm from the box and try just hydrolic steering using the factory box?
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Is your draglink straight, or dropped?
  9. poorboy1
    May 26, 2004
    56
    Newberg,OR
    it is straight. I was just looking at what I could do with it. Might put it in the tubing bender and put a slight bend in it, but then I suppose that would just give it a weak spot to bend on the trail?
    I've already made a new crossmember that is not in the way, Just need to check if it will clear the pan under articulation. I really just need to take the truck out to my dads and put it on the RTI ramp and get some real measurements.
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Most Chevys are going to have to run a bent draglink to clear the engine crossmemeber and keep the TREs at good angles.
    Heres what mine looks like. The draglink is made out of 1 1/4"x.25 DOM, I doubt I will bend it.
    Woops heres the pic:
  11. poorboy1
    May 26, 2004
    56
    Newberg,OR
    good looking steering. The pics I saw where only crossover not high steer. One of the other possible issues I have and I might be getting ahead of myself is the high steer looks as if it will hit the steering arm. Again I might be worried over nothing but never hurts to ask. I will find out for sure this week when I try it I guess.
  12. poorboy1
    May 26, 2004
    56
    Newberg,OR
    I ran my truck up on the ramp today and sure enough the high steer hits the steering arm. The cross over clears the new crossmember though. I will have to run a standard tie rod for now, until I 4 link the front and get some lift. Even with the lift though if I get enough flex its gonna hit again. Is there a different arm that has more clearance?
    I'm only about 3 feet up the ramp less than half way.
  13. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You could buy the double arms that put the tierod behind the axle. It is not cost effective as you have already bought the other arm but you could prolly sell the arms you have and buy the double arms.
    Ira
  14. poorboy1
    May 26, 2004
    56
    Newberg,OR
    That is an option, one I would like to avoid if I could. Not sure if the tie rod would clear the oil pan that way though.
    Is the arm in the picture a drop arm? It was given to me so I'm not sure what a stock 2wd arm looks like. If it is a drop arm then maybe a standard arm would work?
  15. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    That spring looks fairly flat, you could extend your bumpstops to stop the tie rod to pitman are contact.
    Or you could get a pitman arm that doesn't drop as much and re bend your draglink.
    Blake
  16. poorboy1
    May 26, 2004
    56
    Newberg,OR
    I actually can flex the spring another 2" if the arm isnt there. I dont wanna move the bump stops cause then I loose 1/2 my articulation just to gain hi steer. Isnt worth it to me. I will look around for a different steering arm I suppose. Just have to run regular tie rod for now.
  17. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Weird....
    It looks like your tie rod is mounted in FRONT of the draglink. Mine is just the opposite.... :thinking:
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yep thats your problem. Drgalink goes in the front hole while the tie rod goes in the back.
  19. poorboy1
    May 26, 2004
    56
    Newberg,OR
    Thats the pic I've been looking for. Well I installed the unit as I got it. The tie rod and all were already bolted to it. Now If I move my tie rod as this one is the left side will still be under the arm cause there is only 1 hole on the left side, I'll need to redrill but that might work.
  20. poorboy1
    May 26, 2004
    56
    Newberg,OR
    My arms on each knuckle are alot longer, Well this is probly why the guy I got it from upgraded? Thanks for the pic again.
