Dana 60 ID question for Dodge
Discussion in 'The Garage' started by joefl, Oct 8, 2004.
  1. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    I found a wrecked Dodge. Didn't have much time to make a ID on the front axle. It's overly caked with oil and dirt. Whats the easiest way to ID to if it's a Dana 60 or 44? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/waytogo.gif
  2. nvrenuf
    Jan 7, 2002
    13,075
    246
    Mobile, Al.
    Take a look at the steering arm on mounted on the top of the driver side knuckle -
    D44 = 3 studs in a row holding the steering arm to the knuckle.
    D60 = 4 studs in a square pattern holding the steering arm to the knuckle.
  3. joefl
    Aug 18, 2004
    153
    Marianna, Florida
    /forums/images/graemlins/peace.gif sweet, I'll check
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    it will also only have 3 u bolts, the housing has 2 studs to hold on a side of the spring plate
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    also, it will have a kingpin cap with a grease zerk on top of the knuckle instead of a castle nut.
  6. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Dodge front HD D44 Unit Bearing axles have the same setup as well. So it is always wise to check the steering knuckle or look for the 60F on the center diff if possible.
