dana 60 ifs question
Discussion in '1992-Present Chevy & GMC models' started by mudhog, Oct 31, 2003.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    my buddy has a 1 ton chevy with a ifs dana 60 it has the electronic actuator to make the front hubs lock well it went out on him and someone told him about a cable actuated devise to replace the electric one. anyone have any info on this? who makes them where to get them and such?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    awesome thank you very much /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah it's a posi-loc, but it's not a dana 60 ifs... It's built by AAM...
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    I installed the posi-lok in my 95 K2500, and it's a nice unit and enables the use of 2-low, but when locking in the front end using the posi-lok my truck must be rolling to engage the diff. It's not usually a big deal, but if I get stuck in 2WD to the point where my truck won't move, I am unable to lock the front end. Also, I have had the cable break on me while trying to engage the front end. They sent me a new cable and said that they had a bad batch of cables and I haven't had a problem since.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    For several years the actuators used a heater, that made a gas expand, which pushed out the actuator to engage the front diff. /forums/images/graemlins/eek.gif As they age they get weaker. GM now offers a different design, which will bolt up to the older trucks. It's a motor driven actuator. He might want to check with the dealer on that. /forums/images/graemlins/cool.gif
  7. bowtiepower00
    May 11, 2000
    924
    AZ
    That newer setup works well, but in addition to the mechanical actuator you have to buy a harness adapter to plug it in, and the setup gets spendy fast. Rancho used to make a "sure-shift" that did the same thing for way less money, but I'm not sure if they still do. The stock TLA's are junk, I've had more than one that lasted less than 5 engagements.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I get the "good buddy price" at one of the local GM dealers. My cost for the actuator and wiring adapter is about $110. /forums/images/graemlins/cool.gif
  9. bowtiepower00
    May 11, 2000
    924
    AZ
    Hey, you can't beat that... /forums/images/graemlins/pimp1.gif
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats what I have on my '92 Dually and it seems to work OK for now but I have noticed that if its real cold or you are in snow, it can take some time for it to engage.
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Do you have the gas type now? That's the one that gets weaker in cold weather, and can leave you with 2WD only if the actuator is submerged in icy water. /forums/images/graemlins/frown.gif
    Or do you have the motorized one? It is supposed to always engage.
  12. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    My 97 is the same way. A little slow to engage, but stays engaged. Played in 2' of snow last year for two days and never had a problem. /forums/images/graemlins/thumb.gif
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Must be the gas one. I'll run it untill it dies.
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I avoid snow. I found out the hard way that a dually is no snow machine. /forums/images/graemlins/grin.gif
    I sure can plow it when I have some speed up though. /forums/images/graemlins/thumb.gif
  15. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    94-older should be the TLA. 95-up is the motorized version.
    If you go the GM route and upgrade to the motorized version, you could wire it through toggle switch and also get 2wd low-range. /forums/images/graemlins/thumb.gif
  16. bowtiepower00
    May 11, 2000
    924
    AZ
    My 95 was TLA...
  17. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    OK, so what year did they quit using the TLA and put the motorized version on factory? My dad has a 98' sub with the auto trac and has never had a prob, Is this the motorized setup? I am curious because I might buy a late 90's blazer tahoe and need to know what years to avoid.
  18. u2slow
    May 9, 2001
    2,217
    BC Canada
    95 is probably a transition year then. Newer is motorized, older is TLA.
  19. bowtiepower00
    May 11, 2000
    924
    AZ
    I think it's safe to say that Autotrac was always motorized. I wouldn't avoid a truck based on the type of actuator it had, it's a simple swap. You should be able to tell by looking at the actuator itself, the TLA should be small and made of metal, and the motorized version should be larger and made of plastic.
  20. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I wouldn't turn away a truck just because of that, I want a 96' or later for the vortec motor.
