Dana 60 inner axle seals
Discussion in 'The Garage' started by pomai, Feb 28, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    When I removed the ring gear to replace the inner axle seals, there was a large, approx 3" O ring sandwitched between each differential bearing race and the housing. Was that suposed to be there. I can't find any information about these O rings. The axle seals don't come with them.
    Dose anybody know anthing about these O rings. Thanks Ed
  2. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    It's not an O-ring, it's silicone from when the axle was made. They silicone the tubes before they press them into the housing.
  3. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    Not a big shocker coming from me but I have no clue. I pulled my carrier out the other day and didn’t see anything like that. Anybody else…:dunno:
    Never mind, late as usual :blush:
  4. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Do I need to re seal it with silicone again? Thanks
  5. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    hey man- my 60 didnt have any oring type substance around the diff. carrier seals. I agree that it was more then likely just silicone and yes when installing metal seals i always apply a thin layer of silicone around the outer seal to be pressed in EXCEPT on an automatic tranny seal the silicone cane get inside a tranny somehow someway. just put a little on rub it around the seals o.d.
    lata ryan.
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    go down to the chevy dealership and order the d60 inner carrier seals (2 of them).
    you can probably find the part number over on the pirate4x4 dana 60 bible..
    The cheap replacement ones are plastic, the good ones from the dealership have a metal support for when you remove/install the axle shafts keeps the seal from getting destroyed.
    I pulled mine out with a screwdriver, and tapped the new ones in with a mallet and a 2x4 or a big socket to drive the seal in. :thumb:
