Dana 60 inner axle seals
Discussion in 'The Garage' started by ratzila, Aug 10, 2003.
  1. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I'm getting 5.13 gears swapped into my dana 60 front.
    I need to know where I can get the inner axle seals. It's
    the one that prevents water and mud from getting into the
    axle tube at the knuckle. I have tried to search but have
    come up empty.If anyone has a part # for them I would
    appreciated it very much.
    Thanks, David
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    GM will have them, and they are of better quality and design that the parts store version.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that seal does a better job of holding the crub IN the axle tube then holding it out
    donot use it
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    He said INNER axle seal which is highly needed or gear oil will drain quickly from the carrier, as I am sure you know this.
  5. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    I really ment the seals to keep mud and water from entering
    at the knuckles.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    . It's
    at the knuckles.
    what he said. /forums/images/graemlins/wink.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    So if I understand correctly, he is looking for the SBK3 kits? All the seals that go on the outer stub shaft and seal it from getting water and mud into the wheel bearings?
  8. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    No it's not an OE seal, he's looking for a seal that would fit at the outer end of the axle tube. It's been a couple of years ago but a magazine published a "Homegrown How To" about a seal that coincidentally fit the tube and axle shaft, there was a NAPA part number given in the tip.
