DANA 60 INSTALL HELP!
Discussion in 'The Garage' started by 76K5, Sep 30, 2003.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    My Dana 60 in the rear of my truck is suffering from a bent spindle. I think I found a guy who has a housing I can use from aroung the same year. Can I just switch out the carrier, ring and pinion? If so do I need to reset the back lash? The Dana 60 is an oldie, 16 spline 4:56 gears, lincoln locker. Thanks for the help.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    You will have to re-setup the gears just like you were putting new gears in it...every housing is a little different and may require just a little more or a little less shim to get everything in the right spot
  3. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    should work just fine.
