Dana 60 king pin rebuild
Discussion in 'The Garage' started by blazindorito, Jun 13, 2006.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I took apart the king pin's to place washers and I need to know how to put back. I remember it going back from left to right in picture but can't remember if the metal sleeve at the far right goes on top of the spring or ? I know it's a dumb question but it's been 3 weeks since I took apart.
  2. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What is the thing on the far right for??
  4. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    I don't know it was under the king pin cap when I removed it. I was wondering the same thing. None of the pictures with the rebuild or pictures I have seen have this. IT was under the king pin cap though. Hopefully someone can chime in.
  5. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    from what I know it goes 1.)the plastic cone goes over the kingpin itself 2.)the small metal cap sits on top of the on the plastic piece 3.)the spring sits on the metal cap......and are you sure that came from the kingpin--I have no clue what it could be
  6. readymix
    May 30, 2004
    6,706
    26
    I doubt that it belongs there. I have rebuilt my fair share of kingpins and have never seem than before.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    He said it was a sleeve maybe the PO put it in there to keep the spring from deflecting inside the cover while under load. That is the only thing I can see it possibly being for.
    Ira
  8. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    I took both kingpins off and they both had the metal tube, sleeve, I don't know what it's called but they both came from under the King pin cap. I just don't remember how I took them apart. When i tried to put it back together It just doesn't all fit under nicely.
  9. sandawgk5
    Oct 28, 2003
    6,881
    Does the tube slide over the spring or sit ontop of it?
    Ira
  10. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    The metal piece does not slide in the spring. IT would have to sit on top of the spring. When I put it back together with metal piece on top I would have to compress the spring a lot to place the cap on top. Shoudl I put it back on if it had it or should I just replace with washers? Could this have been a possible cause of death wobble? It drove fine with them there. Confused :thinking: :confused:
  11. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    It looks like a VERY big shim that someone put in there to cure death wobble.
    Most people put 2 or 3 1/16" thick shims in there (<1/4") and have positive results, but damn, that thing's like 1" thick! :eek1:
  12. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    lol that is too funny. let us know how it goes.. ie if you get that thing back in. haha
