dana 60 king pin removal
Discussion in 'The Garage' started by jstevenj, Jul 22, 2004.
  1. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    Can someone tell what size hex wrench I will need to remove the king pin tapered post on a Chevy dana 60 front axle.
    I'd like to have it in hand when I open it up.
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I beleive it's 3/4 or 7/8. Anyway, It also takes something like 350 ft lbs as well. I know fortcollinsram did his. You could always ask him.
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    7/8" hex. I used a 3/4 drive, 7/8" hex and a 6' cheater pipe on the breaker bar to get mine off. It worked like a champ but it sounded like something exploded when that sucker came loose /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif Good luck finding such a tool for cheap, I borrowed the one I used.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    7/8" allen wrench. I bought mine from www.fastenal.com as it was the cheapest I could find. I also got a piece of black pipe about 6-7 feet long and used it for leverage to break the old one loose.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    7/8" I used a piece of hex bar stock and a socket. It is on tight though. might want to check out PBB write up on kingpin rebuild.
  6. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I will concur that it is 7/8" and they torque to 600 ft. lbs.
    Good thing I just purchased a snap-on 200-600 ft. lbs torque wrench. /forums/images/graemlins/thumb.gif
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i seen someone get some 7/8" hex and bend it in a "L" shape and use it as a big allen wrench.
  9. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    That's what fortcollinsram did. He said it worked pretty good.
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I bought a 7/8" allen wrench and also a 3/4" drive 7/8" 6 point socket then cut a piece of the allen wrench off and installed it into the socket and used my torque wrench. /forums/images/graemlins/thumb.gif
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the best way to do it right there.
    then the TQ is accurate. use a propane torch to loosen it a bit as well.
    Grant
  12. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    This is what I did after I broke my 3/4" drive ratchet.... A little heat from the torch and it came right off. [​IMG]
  13. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Here in California we have a place called OSH(Orchard Supply and Hardware)I was there today and they sell those 7/8 allen wrenches.About $20.00 bucks I think.
  14. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    /forums/images/graemlins/thumb.gif Yep, thats where I bought mine.
