dana 60 kingpin inclination, how many degrees??
Discussion in 'The Garage' started by 85-m1028, Nov 1, 2006.
  1. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    Seems to me like I should know this but I can't seem to find the specs anywhere... I am trying to put together a few math formulas for setting up proper steering geometry along with a bunch of other steering and wheel combo related items..
    I will be putting a thread up about cause and cure for the death wobble beacause I would like to try and condense all the threads I've gone through into something more timely!!!
  2. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Are you talking about caster?? :dunno:
    The original spec for 1-Ton trucks IIRC was something between 4 and 6 degrees of caster...... which is what I shimmed my D60 to get.
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    The book (for a 1990 V3500) calls for +8 degrees.
  4. 85-m1028
    Apr 26, 2005
    485
    Think of an imaginary line running from the top kingpin through the bottom kingpin and down to the ground... That angle as to how it relates to the flat or horizontal line of axle.
    ---------------------------------------- Not castor!! I know what that is!!
  5. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    I read somewhere that Moog makes a adj king pin for the 60 , something like
    4+ to 4- degrees.A couple of years back so I'm not sure.
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    so camber then? it isnt adjustable. At least not from what ive seen...
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    They still do. At least, its still available. You can get them at Carquest (who brands Moog products for their "blue" chassis parts line), but they are pricy. IIRC they replace the entire lower kingpin. I forget the pn#, but any counter guy worth his salt can look it up.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Camber can be adjusted by using tapered shims behind the spindle.
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Thats right i remember a pirate thread about that... i dont like the idea of doing that though. also unless your caster is 0* it will change as it turns...
  10. 85-m1028
    Apr 26, 2005
    485
    The kingpin inclination is what causes "scrub" depending on your rim offset, Idealy you want the inclination "pivot point" to center in the contact path of the tire.
    The fomula will take the kingpin inclination (degree of incline), distance from center of rim to the center inclination axis, and calculate the distance of where these two lines meet. This will ball park an optimal tire diameter.
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    That's what I was beginning to think you were after, King Pin Inclination Angle. Sometimes called Steering Axis Inclination Angle. Not normally considered a user adjustable angle, so I'd be surprised if it is listed anywhere. You're probably going to have to geometrically construct it from measuring a couple samples.
    Camber is the top to bottom tilt of the Wheel Mounting Surface (WMS) which is NOT the same thing.
    Sometimes scrub is a good thing. In a comp buggy or truggy it can help you in 'hunting' for traction by steering opposite locks. Large scrub causes the inside tire to be loaded harder than when pointed straight.
  12. 85-m1028
    Apr 26, 2005
    485
    I am gonna try and find out what my scrub radius and castor specs were with the stock 235/85 r16 wheels that came with the cucv. that way I can plug in a new rim width and offset and determine what tire height will keep the steering inclination in the same area as factory specs.
    Theory: Input caused by positive tire scrub can be offset with positive castor to a point?
