dana 60 knuckle problem
Discussion in 'The Garage' started by cegusman, Jan 5, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    The tapperd holes were the tie rod connects is oveled out on both of my knuckles. Is there a way I can fix it? Or do I have to spend $400-$500 on new knuckles?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    You could always run hi-steer... :crazy:
    Rene
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    drill them out and run TRE's or i second the highsteer arms.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am almost certain he is having problems with the Tie Rod End hole in the knuckle, drilling out will acomplish nothing.
    You can drill it out to 3/4" and run heims (not the best for the street and longevity), send it out to be brazed up and re-reamed (I don't think brazing will give the original hardness of a factory drill though) or go hi-steer (this is what I would do). Be careful as some highsteer arms (most) are normal mild steel and waller out just as easy (if not easier) leading to shearing of the TRE.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Can't run high steer, Front axle is moved forward 1.5". I guess I will have to buy new ones.:mad:
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Can't run heims, due to all the mud we have down here.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Where do you run into a problem with high steer and your axle being moved forward? Pitman arm clearance or draglink to tie rod clearance? Either one can be solved by moving the tierod behind the axle with the double high steer arms..
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I think it is tierod end to draglink clearance. I don't think it will work behind the axle. I think the tie rod would be laying on my springs.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    With the added height of the zero rate, that could be a problem with behind the axle mounting.
  10. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sounds like I just need new knuckles, or run high steer with full hydraulic steering.:dunno: Would like to do this the cheapest way though.
