Dana 60 Knuckle Problems.
Discussion in 'The Garage' started by ryan22re, Sep 12, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I am slowly going through my D60 when I ran into a problem. On the passenger knuckle where the crossover steering arm would bolt down, one of the bolt holes is seriously ****ed. The bolt wasn't even tight, and pulled out all of the threads with it when it came out.
    There will be no rethreading of the hole, as there is very little material left. Helicoils make me nervous, not always, but in this application where the steering will be pushing on the studs. Does anybody have an experience with helicoils this big and load applied to it? Can I drill it for a bigger stud/bolt?
    Or should I start looking for a passenger side knuckle? Here's the pic of what's left of the bolt. The hole in question is the one in the upper left hand corner of the pic.
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I had to helicoil one of my mine, it turned out great. It held up fine for a year. With studs on the histeer arm, the holes don't get stripped. I wound up busting a knuckle, and since have gone to Dedenbear.
  3. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    If you install the helicoil correctly... It will hold up just fine. I have used HC's in much more critical situations than this. Let us know how it turns out.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I'll probably get the knuckle off and try to set it up in the mill or drill press at work to make sure I get it straight.
    What's the thread size btw? My guess is 1/2 20.
