Dana 60 knuckle swap
Discussion in 'The Garage' started by M-1028, Mar 25, 2005.
  1. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    Hey guys, just wondering if anyone has swaped the driver and passenger side knuckles to put the tie rod behind the axle. A friend of mine did it and it seems to work but I was wandering if there would be any ill effects in the long run. The only thing I see a problem with is the brake calipers face tward the front of the front of the axle instead of the factory location.
    any info will help, thanks
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    How did he do this and not have the tie rod hit the snout of the diff?
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My tierod is behind the axle, but I didn't swap my knuckles... I just have reversed Hi-steer arms. I have never heard of swapping the knuckles, and if it works I would love to see pic's... because it sounds like somebody is pulling somebody elses wang...
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I could see it working on a Ford axle, high pinion and lower tie rod points. Tie rod would still be quite low and vulnerable though.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    And the calipers and lines would be all goofed up.
  6. M-1028
    Feb 2, 2005
    217
    Sealy Tx
    I know it sounds stupid but like I said a buddy of mine did it and it SEEMS to work, the truck dose not see much street use. As for the tie rod he made it in several pieces to go around the housing, and yes the calipers look real funny the way face, but like I said it works and I was just working if it would wear anything out over time. Thanks
  7. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Say what !
    It aint April 1st,is it?
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    alright, I see no reason there would be any wear issues associated with this. Caster and Camber wouldn't be affected that I know of. Only thing I can think is maybe you would need to adjust your steering stops a little. I guess the axle tube would kind of protect the tie rod in this configuration. If you do it, post up with pictures.
  9. bagged beast
    bagged beast Registered Member
    Feb 15, 2005
    10
    sealy texas
    This message is about my truck and I have done it and it seems to work. I have about 6000 miles on it and it all seems normal. I have no abnormal wear on any parts and it all bolted up. I am also running full hydro on it but as far as the bumpstops go that doesnt seem to be a problem either.
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    How is your tie rod made?? you say its in several pieces, it seems like it would have to be pretty beefy not to bend where each piece goes together.
  11. bagged beast
    Feb 15, 2005
    10
    sealy texas
    My tie rod is made of 1 3/4 .250 DOM tubing with 3/4 heims at the ends with no problems
  12. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Why not just go behind the axle high steer and be done with it?
  13. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Is the tierod straight? Hi-steer? Any pictures?
  14. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    it doesnt sound like the tie rod is straight since he said it was made out of pieces, I would imagine that it looks like a -u- so that it can go around the pinion. Not sure if I would want to have bends in my tie rod though.
  15. dark eternal
    dark eternal Registered Member
    Jan 15, 2004
    22
    Dallas, Tx
    if your running your crossober arm backwards this will screw your ackerman up. Even flipped it might...
  16. bagged beast
    Feb 15, 2005
    10
    sealy texas
    Im not running crossover im running full hydro so the only thing that is affected is the tie rod location and no the tie rod is not straight it has a bend at the pinion
  17. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    BAHAHAHAHA....
    The reason for moving it BEHIND the axle in the first place was to keep it from bending...and the first thing you had to do...WAS BEND IT!!
    Kinda defeats the purpose IMO.
    Rob
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Easy there yield, no need to scare off a new poster.
    Moving it behind the axle does protect it, but the bend(s) is/are not ideal. Is it possible in your set-up to make one that is straight by moving it on the steering arms? Still on leaf springs, right?
  19. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Bringing this back up...
    It's 1.750" ODX.250" wall. That's cage material. It's not going anywhere, guys, unless he totally goofed his bends or something.
  20. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Holy crap, nobody should ever make their cage from 1/4" wall tubing.
