Dana 60 Knuckles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bgwhlr, Aug 21, 2003.
  1. bgwhlr
    bgwhlr Registered Member
    Feb 18, 2003
    14
    Tigard, OR
    Hey got a problem with wobble in my 42" swampers. I had bad bearings and bushings in my knuckles. I replaced everything from the nylon bushings on top to the bearings races, and bottom pin. The races seated tight and so did the bearings. The drivers side bottom is still wobbling. Please help, don't know why there is play still. /forums/images/graemlins/confused.gif
  2. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    what sort of condition are you balljoints in, i know my lowers are gone in my dana 44 and when i go backwards the thing shakes like its gonna fall apart.
  3. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    I assume you replaced the springs?
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    He doesn't have any, the D60 he has uses kingpins.
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Did you replace, or at least preload the top spring w/ some washers?
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If preloading the springs on the kingpins solves the problems, then your springs are worn out.
  7. bgwhlr
    Feb 18, 2003
    14
    Tigard, OR
    hey even though on the bottom the whole truck weight is on the bottom knuckle forcing it up, would new springs help that much? I didn't replace the springs, because they seemed pretty stiff still /forums/images/graemlins/1zhelp.gif
  8. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Pre-loading the kingpin springs has resolved a lot of DW issues a lot of people have had. Based upon what you have said, you have a lot of things you could check, especially the 42's. Placing a couple of washers on the springs to give them a little more pre-load is a very easy fix.
    Before comparing to a new spring, I thought my old spring was okay, but as you can see it wasn't. Replacing the springs, resolved my DW issues.
  9. bgwhlr
    Feb 18, 2003
    14
    Tigard, OR
    hey thanks for the great advice, that pic. shows a lot. I think I'll go back and replace those springs
    /forums/images/graemlins/thumb.gif
  10. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I had the same prob with the same tire/axle combo. Did the springs and bushings and it was completely gone. Make sure you take a look at your stabilizer(s) are good while you're down there.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    That is true, but the washers are at least a good way find if that is the problem.
