dana 60 limited slip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bushmaster, Jun 2, 2003.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    how hard is it to replace clutch packs in a dana 60 its outta a 77 ford /forums/images/graemlins/ignore.gifits the 32 spline if i remember corectly any i make aftermarket packs or is this a dealer item ?
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Powr loc, right? Very easy. Take it apart, clean it. Lube up the clutches, and put it back together with the belvels facing the correct way. At work ours are made by Spicer, I donnt know for sure if theres other companies out there that make anything.
  3. bushmaster
    Jun 1, 2003
    146
    ct
    your saying not to replace clutch pack just clean them???
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I have a copy of the dana 60/70 powr-loc service manual in the link in my signature if it's not good enough I can try and fax it to you.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI if it is a Track-Lok
    you may a speacil tool.
    Good luck
