dana 60 lockers ?
Discussion in 'The Garage' started by 4x4k20, Oct 23, 2005.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    will a dana 60 rear locker be the same for a chevy dana 60 front?
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    If it's a 35 spline, it will be.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Probably not, most rear dana 60's are full floating, which means that they are 30 spline with much smaller shafts. Front dana 60's are 35 spline.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Wether or not the axle is full floating has nothing to do with how many splines the shafts have. There are 35 spline dana 60 rears out there but they are pretty rare.
    To the original poster. Chances are the locker will be 30 spline and will not work as is. You might be able to replace the side gears with 35 spline gears but I am not sure if that is cost effective or possible but might be worth lookin into.
    Ira
  5. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    the guy says its a 35 spline removed from a dana 60 rear. its has 12bolt pattern. so do you think it will work
  6. 1977k5
    May 26, 2003
    9,995
    133
    If its 35 spline it should work (assuming it is the right carrier break).
  7. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    when I bought the d60 ARB air locker, there were 2 available on the webpage. RD35 and RD42.
    RD35 is 35 spline chevy, dodge, ford apps, FF front
    RD42 is 35 spline for ford rears, FF
    IIRC, that is the breakdown.
    So, I think there is a difference in the carrier itself.
    Pretty sure the intall kits are the same though.
