dana 60 locking hubs
Discussion in 'The Garage' started by dheavychevy38, Apr 28, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    after i lock my hubs they won't unlock unless you jack up the front of the truck any ideas
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Since your front is welded it is bound up and under tension. You need to relieve the tension before they will unlock. You might be able to go strait for a few feet and see if that helps, or just keep jacking it up until you put the locker in.
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Your sig says soon to have 488's and a locker up front, are your gears the same ratio now?
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I think he means, "soon to have 4.88's, and a locker up front"
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    my warn premiums are hard to engage sometimes... i just roll the truck straight forward a few feet, or a back a few feet and try again. It works.
    j
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Shift the transfer case into 2wd and the tranny into neutral and drive back and forth for a few feet. This will get the bind off the front end and should let the hubs unlock.
    Harley
