Dana 60 Noob Q:s...
Discussion in 'The Garage' started by sebban, May 5, 2006.
  1. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    I´ve checked on summit and I´ve tried search here..
    Tie-rod ends, are the the same for 10bolt vs. dana 60??? (it looked like the same part number too me..)
    Attachment to the springs, I know you use u-bolts on three places, but the fourth? Do you use a regular bolt? If so, what size and thread?
    Thanx, Sebastian
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    do you have a d60 front or are you doing some searching?
    I know my tierod ends were different size between my d44 and my d60... physically the d60 tierod was bigger... IT WAS HUGE :haha:
    also yes drivers side (gm d60) has 2 ubolts as the passenger side has 1 ubolt and 2 studs that are in the axle. You use 2 nuts to bolt the leafpack down...
    however some loose or break the stud and use grade 8 bolts. I have the studs...:bow:
  3. sebban
    Jan 18, 2005
    63
    sweden
    I got the axle yesturday.. (and I have brand new parts for a complete 10bolt still in the boxes but I don't want to tear it down unless I have new parts waiting)
    Ok, the studs in my axle were gone so I guess i'll just get some bolts.. :)
    thanx!!
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    the tapered part of the tie-rod ends are the same, but the threaded portion on the d60 tierod ends is larger.
