Dana 60 or Dana 70 Rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TxK5Blazer, Jul 8, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am buying a set of axles and the guy has both a dana 60 and dana 70 rear which would be better to have on my K5 there is only a $50 difference in the two. need some input I am picking them up this weekend ......Jason
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    D70. its closer equivalent to the 14bff than the d60 rear is.
  3. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I second the D70 you can also go lower than 5.13 gears if you ever need to to run those bigger tires you will eventually get. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Eric
  4. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    The 14 bolt FF is the axle that you can only go down to 5.13s on. Dana 60s can have as low gears as dana 70's, I think the lowest I've seen is 7.15 or somethin close to that. But I'd say the price of lockers offsets that. Then again, if you're set on one of those two axles, I'd say go with the D70 because from what I hear, the axle shafts are almost the same size, but the ring gear on a D70 is around 10.5" and the D60 is like 9 3/4". Not a huge difference but hey, every little bit helps right.
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    How many splines are in the Dana 60? Many early Dana 60's have 30 splines and are relatively weak. If the Dana 60 has 35 spline shafts it is very close in strength to the Dana 70. Almost all Dana 70's had 35 spline shafts. One drawback would be weight. I'm not sure how much the difference is but I know the Dana 70 weighs more.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I'd go with the D70 any day since they are more comparable to the 14FF. The D70 has a slightly larger ring gear diameter at 10.54 inches compared to the 14FF at 10.5 inches.
    ALL D70's are 35 splines. The only D60's with 35 splines are the newer axles like in the Dodges. Almost all of the D60's from older trucks have somewhere around 16 splines or so. The axle shaft diameter on the older D60's are also smaller and weaker than the 14 and 70 which are at 1.5" diameter. You can't buy an aftermarket 60 shaft that is 1.5" and 35 spline and stick it into the older 60 housing because the spindle hole is not large enough to let it slide in. There was an article in a magazine where ORU did this boring into a smaller 60 spindle hole with some special bit. Very time consuming a costly, too.
    Stick with the 70 and have fun picking out gear ratios since they are available for the 60 and 70 in gears all the way up to 7.17 ration. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I will put in a vote for the Dana 70 as well . A "B" series 70 is the most common ( or so it seems ) but becareful if it is from a late model Dodge - they come with odd ball 32 spline axles and a crush sleeve instead of shims for pinion pre-load . HTH , Tom
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i don't know if all 70's have it, but a buddy of mine has the HD one and the carrier splits like the 14, so the locker itself was also as cheap as the 14
  9. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    pull the axle shafts on the 70 before u buy!!! if it aint 35 spline u don't want it. some are 32 spline &amp; some are smaller than that. u can't get any lockers for any of them except the 35 spline. there is 3 versions also d70, d70 hd &amp; 70u. all are fine as long as u get a <font color="red"> 35 spline version</font> .
  10. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Go for the beef! Get the 35 spline 70 (if he has one). /forums/images/graemlins/thumb.gif
  11. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Uh yeah I knew that. I meant that if wanted to go lower than 5.13 gear ratio he would want to get the Dana 70.
    Eric
  12. afroman006
    Aug 21, 2002
    2,876
    Oops my bad. Just went back and re-read it. My mistake.
  13. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    Go with the 70.I run one with 5.86s and love it.
  14. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The D70 is a great axle. It is usually a little pricey when compared to the 14BFF though and not usually a plug and play deal. You DO want to avoid a 70-3HD axle though. GM thought that it would be great to move the pinion center line on these axles. As a result they are a real odd ball.
    Mike
  15. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Only the Ford and Dodge axles have that low spline count problem /forums/images/graemlins/wink.gif From 1960 up GMC was using 30 spline Dana 60's (Chevy was using Eaton's with course splines). Anything 1959 or earlier I am not sure about.
    I am going to use a Dana 60 because it has better ground clearance (due in part to the smaller ring gear) and mine came from GMC with 4.10's and a Power Loc in a 1966 GMC 2wd 3/4 ton. It also has 42.5" spring spacing. For what I plan to use the truck for a Dana 60 is more than strong enough for me. I am using my K10 as a 3/4 ton for towing medium loads and mild offroad driving.
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you go 70 you can upgrade it to 35spline with dana parts if it does not already come with them.
    I used a dodge70 w 32 splines and stepped up to detroit and 35spline axles.
    the 32 spline with 4.56 and higher gears has a detroit available
  17. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    mj, any issues fitting the shaft through the spindle? Or is that just a D60 issue?
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no fitment issues, bolt in
  19. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
