Dana 60 part number please?
Discussion in 'The Garage' started by K5thatShmobs, Mar 11, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Im looking for the Dana part# for the driver's side knuckle spring cap (otherise known as the steering arm). I have the GM part #, but I need the Dana #. The part is number 11 in the picture below:
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think I posted that in a reply to Chevycagal a while back.
    number 43 in this list, hop it is readable /forums/images/graemlins/smile.gif
    001 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    002 GM_60F(TAB) TAB BILLS
    003 34643 SLINGER - PINION BEARING INNER
    004 706046X INNER PINION BEARING KIT
    005 706375X KIT - DIFF & PINION ADJ SHIM
    006 30982 BAFFLE - PINION BEARING
    006 706359X KIT - PINION BRG ADJ SHIM
    008 706045X OUTER PINION BEARING KIT
    009 42737 THRUSTWASHER - BEARING
    010 42449 SEAL - PINION
    011 2-4-3801X END YOKE ASSEMBLY (INC 10)
    012 34592 SLINGER - END YOKE
    013 30275 WASHER - PINION NUT
    014 30271 NUT - PINION
    014 GM_60F(VAR) VARIABLE PARTS TABLE
    015 GM_60F(VAR) VARIABLE PARTS TABLE
    016 34822 BOLT - CARRIER COVER (QTY 10
    017 GM_60F(VAR) VARIABLE PARTS TABLE
    018 34687 GASKET - CARRIER COVER
    020 48632-1 BOLT - DIFFERENTIAL BEARING CA
    021 706047X DIFFERENTIAL BEARING KIT
    022 706378X KIT - DIFF BRG ADJ SHIM
    023 Not Sold Separately NO MASTER RECORD
    024 30266 BOLT - DRIVE GEAR (QTY 12)
    026 34367 PINION
    027 34729 THRUST WASHER
    028 34730 THRUST WASHER
    029 44810 LOCK - DIFFERENTIAL SHAFT
    030 30263 DIFF SHAFT
    031 36487 SEAL & GUIDE TUBE
    031 706395X KIT - KING PIN PARTS
    032 620058 SEAL - KING PIN - UPPER
    033 37305 RETAINER - GREASE
    034 706150X KIT - BEARING - KING PIN - L
    035 41777 SEAL - OIL
    036 31026-1 SCREW - STOP
    037 500381-3 NUT - HEX SLOTTED
    037 500381-3 .375-24 HEX NUT
    038 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    039 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    040 500175-1 FITTING - LUBRICATION
    041 30875 NUT - HEX TAPERED
    043 38139 ARM - STEERING (LH ONLY)
    043 620132 CAP - KING PIN - UPPER (RH ONL
    044 37307 GASKET - KING PIN CAP
    045 37300 SPRING - PRESSURE
    046 620180 GEAR
    047 41886 BUSHING - KING PIN
    048 37302 PIN - KING
    048 72837X KIT - RIGHT KNUCKLE ASSY (49,
    048 72838X KIT - LEFT KNUCKLE ASSY (50, 5
    049 41893 RIGHT KNUCKLE
    050 41894 LEFT KNUCKLE
    051 37879 BOLT - HEX
    052 37299 CAP - KING PIN BEARING LOWER
    053 500357-13 LOCKWASHER (KING PIN CAP - LOW
    054 500412-13 BOLT - HEX (KING PIN CAP - LOW
    055 GM_60F(TAB) TAB BILLS
    056 37308 SLINGER
    056 700014 KIT - SPINDLE SEAL & BEARING
    056 GM_60F(VAR) VARIABLE PARTS TABLE
    057 37311 SEAL - OIL
    058 37312 SPACER - WHEEL BEARING SPINDLE
    059 620062 SEAL - NEEDLE BEARING
    060 620063 NEEDLE BEARING - SPINDLE
    061 GM_60F(VAR) VARIABLE PARTS TABLE
    062 36880 NUT - BRAKE MOUNTING
    063 48816 SEAL - GREASE
    064 706411X INNER WHEEL BEARING
    065 706074X INNER WHEEL BEARING KIT
    066 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    067 GM_60F(VAR) VARIABLE PARTS TABLE
    068 GM_60F(VAR) VARIABLE PARTS TABLE
    069 GM_60F(VAR) VARIABLE PARTS TABLE
    070 GM_60F(VAR) VARIABLE PARTS TABLE
    071 GM_60F(VAR) VARIABLE PARTS TABLE
    072 GM_60F(VAR) VARIABLE PARTS TABLE
    073 GM_60F(VAR) VARIABLE PARTS TABLE
    074 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    075 35830 GEAR, TRAC-LOK
    075 707083X KIT - DIFF PLATE & DISC (T/L)
    076 Not Sold Separately NO MASTER RECORD
    077 Not Sold Separately NO MASTER RECORD
    078 Not Sold Separately NO MASTER RECORD
    079 40835 CLIP - DIFF CLUTCH RETAINER
    080 Not Sold Separately NO MASTER RECORD
    900 GM_60F(TAB) TAB BILLS
    901 GM_60F(TAB) TAB BILLS
    902 GM_60F(TAB) TAB BILLS
    903 GM_60F(TAB) TAB BILLS
    904 GM_60F(TAB) TAB BILLS
    905 GM_60F(TAB) TAB BILLS
