dana 60 pinion yoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surpip, Oct 16, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the new 60 i got has the strap style youke, and i ahve u bolts from my other one, so im thinkin i should be able to drill out the threads right? it looks as though ther is enough flat area behind there to fit a nut on them.... good idea or bad idea????? /forums/images/graemlins/1zhelp.gif
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    FYI
    Some guy on pirate has Tall Yokes U bolt Style for $70 that are very nice 1310 or 1350
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i had 1410 strap style yokes, i wanted to drill them to use u-bolts. the problem is the u bolts are not as wide as the holes for the straps. i put mine in a mill & machined out the holes this worked well cause i could make the new hole were it needed to be instead of were the strap hole was. the u-bolts were larger diameter so there was only a few threads left from the original holes
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Bad idea. Call Jessie at High Angle and get a new yoke from him. It come with Ubolts and costs around forty bucks.
  5. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Or go up the road to WFO Concepts in Auburn. Trevor is a cool dude to deal with.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    right on thanks alot /forums/images/graemlins/waytogo.gif
