Dana 60 Power Lock
Discussion in 'Parts & Trucks Wanted' started by nvrenuf, Jul 2, 2006.
  1. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Edit...
    Ok guys, I found one local that I just couldn't pass up. Thanks for all the help looking!!
    Thanks again b454rat, I hope you see this before you go to the salvage yard. :thumb:
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I found a Dana 60 rear in the yard the other day that had 4.56s, I'll pull the cover and see what it is. I have a set of PL side gears that I don't need that can sell yah.
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Been there done that.
    A Detroit Locker is more streetable than a Power Lock. At least the Detroit will unlock. A LS won't until you get a tire off the ground, then the tire in contact will spin freely...:crazy:
    Why you going with a LS?
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I actually intend to restack the clutch to more or less lock it up. The reason I don't want a Detroit is I've heard a lot about the guts exploding from the shock of an axle breaking. I'll be running a 4spd, Doubler and 42's, I don;t plan on breaking axles but I think it may be a possibility.
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    b454rat, sorry I got wrapped up replying to DPI and forgot to reply. :crazy:
    If you could check that one that would be great! I have some 35 spline side gears (from my D70 P/L :doah: ) so I really just need a buildable unit for a 60. I appreciate your taking the time to check it and if the price is reasonable I'll gladly take it. :wink1:
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I've got a builder unit out of a ford 60 with 16 spline side gears. Needs gears and clutches, but it's a 4.10 carrier. If this might work, PM me.
    Thanks, Jimbo
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Good point about the shock load and breakage. I know my power lock couldn't hold my 42's, but it was a stock type setup.
    bttt for a bro.
    dp
  8. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Wifey has a baby shower to go to Saturday afternoon, so no way in hell am I going, so will try to hit the yard then. That will be the only time where I will have time till next weekend.
  9. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
