dana 60 problems with video *FIXED*
Discussion in 'The Garage' started by BranndonC, Apr 5, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    www.branndoncoelho.com/temp/rotor.wmv
    the brake pads fit with out falling out when the bearings are out, but when i put them in, it pushes the rotor out and the pads are not held in at all /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: dana 60 problems with video
    Um, did I miss another post that goes with this? Why are you trying to put the pads in there with no caliper?
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    web page
    the reason is that the rotor doesnt sit far enough for the caliper to hold the brake pads in place. What i mean is if i slid the caliper on with the bearing on, the pad would still slide around loose, it doesnt make a difference here. IS there a pin/clip that holds the pad to teh caliper? because when i took mine apart there was nothing like that holding them on /forums/images/graemlins/dunno.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Brandon, after watching the video and seeing the space between the caliper mount before and after the bearing, its my assumption that you installed the caliper mount brackets wrong. That is, if you removed them. If you did remove them, its possible you may have got them turned around. The bearing hub is not going to sit as far back with the bearing installed as it did not without the bearing. Seeing the gap widen after you installed the bearing made my guess the caliper mount brackets are installed wrong.
    But if you never removed the caliper mount brackets, ignore the above comments. /forums/images/graemlins/whistling.gif
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Caliper brackets can't go on backwards, the bolt circle is not symetrical.
    On my brkae pads, the one torwards the piston has a clip that holds it into the piston bore. On the outer one, it just floats around.
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    got a part #? or correct name i could give to napa
  7. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    They have them in the help section, they can't get them by looking them up the dealer could. I believe they were called disc brake pad clips in the help section. take a pad with you to test fit as they should have different sizes.
    If he did what I did you can put them on the wrong side or switch the order the caliper mount and spindle go on. That will teach me to take it all apart wire wheel everything together then figure out what goes where.
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    The caliper brackets can go on left for right or even in the wrong order from the 'C' out.
    Either way will cause fitment problems.
    Rene
  9. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I just edited mine to say that, since I did that!
  10. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Rene
    so should i try and turn the caliper mount so its on the other side and sticking out more?
  11. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    your spindle goes on before the caliper bracket. give thata try.
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif i didnt put this axle together, someone else did. But i figured that out, and took pics to confirm. Is this the correct setup?
    this is how it was set up before
  13. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yep looks like you figured it out. /forums/images/graemlins/waytogo.gif
  14. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    now before i bolt it back together, i was wondering if these were required?
    " On my brkae pads, the one torwards the piston has a clip that holds it into the piston bore. "
    or optional
  15. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I bought loaded calipers that have all the hardware and they don't have that clip. My 10B calipers did, but not the D60 /forums/images/graemlins/dunno.gif
    Chirs
  16. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Did you switch the caliper brackets around? The pics look the same to me /forums/images/graemlins/dunno.gif
  17. chevystepside
    Sep 23, 2002
    147
    leadville colo
    you got it. thats the correct way with the spindle first then the caliper bracket
  18. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    or optional
    all chevys use thoise unless you want a flopping pad, and yes without it they can fall out, those arent in the grooves like the inside
  19. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look closer Chris. /forums/images/graemlins/wink.gif The flange on the spindle is closest to the knuckle in the "correct" picture. It's farthest from the knuckle in the "incorrect" picture. /forums/images/graemlins/yikes.gif
  20. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    they can go on backwards. well, kinda. side to side can be swapped to offset the calipers incorrectly.
    i ALMOST did it a year ago when i had my D60 appart for way to long.
    i cant run out and look at my truck to find out, but i think his may be swapped side to side.
    Grant
