Dana 60 Question (Bill Of Materials)???
Discussion in 'The Garage' started by Flexy K20, Mar 28, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Is there any way to find out more info on my front Dana 60 if the Bill Of Materials was lost to rust? Thanks
    -fLeXy K20
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    i've had really good luck, with soaking the axle tag in a product called rusticide. Its a phospheric(sp) acid. after about an hour the rust is all gone, and you can make out the info on the tag. your time may vary of course. I have done this almost a dozen axle tags, and its worked every time. I some times have to wipe some paint into the numbers to make it out. Also the Bill of materials should be on the axle tub. If you cant read it on the tube, acid would work there to.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    That should work, I've heard of cases where they were able to recover the case number on a HD that had the engine number filed or ground off by using acid on it.
