Dana 60 question
Discussion in 'The Garage' started by ryanstrucking, Nov 5, 2006.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    I have a Dana-60 front minus the front carrier and carrier bearings.
    My question is, can I take a set of bearing caps from another diff and use them in this diff? Or are they like main caps on a motor and you can't mix and
    match them?
    Thanks in Advance for your time.
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    no man, no mix and match on axle caps...
  3. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    I was afraid of that.
    Thanks for the input.
  4. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    man that reply sounded just like the hot geeky chick in computer class... :X
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I'm going to go out on a limb and say yes you can swap caps from another axle, but only because you can buy billet caps for a given axle and there is no mention of having to machine anything for them to work.
  6. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ehh me thought he was talking about something from other than a 60... id call dynatrac and ask... but i think you can use gm d60 caps in a gm d60 of the same vintage...
  7. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Glad you got a rise out of that:doah:
    OK.
    Can I,or can't I take the bearing retainer caps from one GM dana 60 front diff and mount them in another dana 60 front diff as they are both late 70's/ earlly 80's.
    Round 2?
    Thanks in advance for your input once again
  8. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    yes, you can....
