Dana 60 question
Discussion in 'The Garage' started by MudFrog, Jan 8, 2003.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I found a guy fairly close by that has a Dana60 and Dana70 with 5.88 gears from a Dodge M-715. He only wants $450 for the two axles. Would there be alot of changes that would need to be made to make it work? I'm also assuming they have drums up front?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's going to be a closed-knuckle 60 also. From what I hear they aren't nearly as strong as the later open knuckle design... /forums/images/graemlins/frown.gif </font color>
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    That Dana 70 is a good axle.
    The Dana 60 from a Kaiser is going to be a closed knuckle, like Shaggy said.
    It uses the same axleshaft ujoints as a D44 (297-x superceded by 760-x) and is really no stronger than a Dana 44, where it counts.
    -- Mike
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok.. so no need to upgrade from my 10 bolt then.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    M-715's have not been made since the late '60s so they have lots of age on them and can make finding parts difficult. You can get a Detroit locker for the rear 70 and the install is basically the same as a 14-bolt FF. The axleshafts are rather course splined and probably not super strong. The rear 70 is also offset to the passenger side which could make a swap difficult. As already mentioned, the front will be a closed knuckle design with drum brakes. The front is also set up for a spring-under suspension. The final problem is the funky big 6-lug wheel bolt pattern so you would be stuck with either the stock skinny split rims with tubes, or custom rims. My personal opinion would be to not mess with them.
  6. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Yea.. I already emailed him and told him I wasn't interested anymore.
