dana 60 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Michk5, Aug 22, 2003.
  1. Michk5
    Michk5 1/2 ton status
    Jul 19, 2002
    139
    Misawa Japan until December...moving to Wichita Ka
    Can anybody tell me if a dana 60 form a dodge will bolt right up into a chevy(k5) What exactly are the differences between the chevy and dodge 60? Why is it that everyone prefers the chevy 60? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gifAny help on this would be appreciated as I in the market for a 60-Thanks Matt
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    dodge dana 60's have 1.5" wider spring perches. this is not a problem though, cause if u are running a lifted spring u can pull them out at the bottum 3/4". so it is bolt in. other differences are the spring plates are a different bolt pattern. u will have to run the dodge spring plates, again not a problem unless u were wanting to keep your sway bar. make sure it is not a 61 frt. they are more common in the dodges. also make sure the dodge frt is a internal locking hubs, some of the older ones were external. knuckles out most are the same as a chevy. only difference in the outers that i have seen is the spindle nuts. internally the only difference is the dodge inner axles are different lengths than the chevy.
    hope that helps. i would run whatever i found 1st.
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    the dodge perches are only 1/2" wider, the springs needs to be pushed out a 1/4" on each side.... Az-kickin offroad can make you some offset bushing for your springs that will push them out a 1/4 inch on each side.....
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I second the above quote. /forums/images/graemlins/thumb.gif
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    o.k. so i stand corrected at 1/2"
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i was told the dodge d60 is also not as strong as the chevy.... i heard that cuz i was tryin to buy a 79 power wagon with a d60 front.. but now im gettin a 79 gmc k35 with a front d60 /forums/images/graemlins/deal.gif
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I dunno where that came from but i know that the axles on my dodge 60 do not neck down, the u joints are the same. The only time i broke anything was when i was wheelin with out the steering stops in, and took out a u joint and short shaft.. but that was obviously my bad and not the axles.....
  8. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    If you were talking about an old Power Wagon w/ closed knuckles and small u-joints, that would be true. The open knuckle/disc brake era p/u D60s are the equivelent of the GMs of the same era.
  9. Michk5
    Jul 19, 2002
    139
    Thanks for the info guys--Matt
