Dana 60 Question
Discussion in 'The Garage' started by merace19, Nov 9, 2003.
  1. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    I have 2 dana 60s frontends One of them has a different hub on it. The 3 others have a smooth cone shape all the way to the locking hub. The other one had a ridge around it near the studs for the lug nuts. Any reason for this?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like a Dodge bearing hub. The Dodge version is more a straight body while the GM version is a tapered type. The GM tapers wider to the lugs. /forums/images/graemlins/thinking.gif
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] How about sharing one? /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
  4. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    No, all my 60's taper up. Its just the one hub as a little ring where the rim sets on. But the other ones dont have that.
  5. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    I not saying it could not be a dodge though. Seeing that it has a different locking hub also. /forums/images/graemlins/ears.gif
  6. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    Got any pics. It'll make it eaiser to tell.
  7. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    Ok i went and looked at it. It is more straight than coned. And it has letters and numbers raised on it. Where on the other 3 they dont have anything. So i guess it is a Dodge.
    NEW question. Is it ok to have a dodge part on my Chevy? If so that makes me have more choices in the junkyard to look at. /forums/images/graemlins/rotfl.gif
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes a dodge dana 60 will work on a chevy my dana 60 is a dodge dana 60 and has been great for 2 years now /forums/images/graemlins/thumb.gif you just need a chevy steering arm and yoke and you need to spread the springs slightly apart
  9. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    It looks like only the hub was used not the whole axle. So i guess a dodge hub will fit a chevy? /forums/images/graemlins/confused.gif
  10. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I'm sure it most likely is a Dodge hub because they are more plentiful (internal design with non-tapering hub used from 89-93) and the different locking hub but GM did use that version for one year, 1991. My 91 crew cab has a hub like the one described (straight barrel with raised lettering and a step at the inner most point for the rim to rest on). This was the only year GM used it and all of them had this different design hub.
  11. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The spindles, stub axles and bearing hubs interchange between Dodge and Chevy. Dodge did use 2 design hubs but either will work on either axle. The spindles and stub axles share the same Dana parts #'s for Dodge and Chevy.
    The Dodge rotors are thinner but the same diameter. I believe there is something different about the Dodge caliper bracket but I'm not sure. I would still think the Dodge bracket would interchange.
    You might take a look at Billavista's D60 tech article on Pirate for other interchange and part number info if needed. /forums/images/graemlins/thumb.gif
