Dana 60 Questions?
Discussion in 'The Garage' started by Bluekrow, Sep 1, 2005.
  1. Bluekrow
    Bluekrow Registered Member
    Aug 16, 2005
    33
    Cedar, MI
    I just finished mounting a 8'' lift and a Front Dana 60 but when I went to mount the tires they wouldn't fit the hubs?? Are 1 Ton rims different? Thanks for your help!
  2. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Where do they hit? in the center? Or is it on the lugs?
    My brother has a Ford 60 under his...i think maybe he had to machine the hubs...?
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you're running 15" wheels you will need to grind the calipers for the wheels to fit.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    In stock form, you need 16"+ wheels to clear a D60 caliper with reasonable back spacing. However, simple grinding and an afternoon of effort can allow you to mount 15" wheels on your D60. I run ground calipers on 2 of mine with no issues. Check this out for more info.
  5. Bluekrow
    Aug 16, 2005
    33
    Cedar, MI
    The center of the wheel itself doesn't go over the hub , I'm trying to put stock steel 16.5 chevy rims on so I can move it around. Thanks for all your responses.
  6. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    My brother's stock chevy wheels wouldn't fit on my 2500 4x4 Ram. Something's going to have to be cut :D
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so the center hole in the rim isnt big enough? just grind that down
  8. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    need ford rims..
    Ford 8 lug rims have the largest center hole--GM and Dodge rims have smaller center holes.. :crazy:
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Where did your axle come from? All GM 3/4 and 1 ton wheels are the same AFAIK.
  10. Bluekrow
    Aug 16, 2005
    33
    Cedar, MI
    Thanks for all your help but it turns out I have a Dually front axle and the hubs are totally different!
