Dana 60 questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rusty68, Jan 29, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    A buddy of mine has a dually for sale or parts. Its a 1981 1 ton 4x4. So wouldnt this have a dana 60 axle in the front and a 14 bolt rear? Would it be worth buying them both as a set for $600.00? I am not interested in weird dual wheels or offset front rims. What would it take to return them to normal style axles? Also, what gears came in the dually?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    First the dually came with a Dana70 rear and Dana60 front, and to change the width to SW status, you will need a lot of work and expensive.
    I would suggest you get a set from a SWR.
    But if you want to make some money on them I want a dually set and I would pay you 700 for them plus shipping to CA 95827.
    PM if interested.
    /forums/images/graemlins/thumb.gif
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    changing a DRW 60 to a SRW 60 isn't that bad. i've seen srw hubs on ebay for $75 each. i chose to have mine machined for $250 but you can have it done for much cheaper. here some pice of the conversion http://coloradok5.com/photos/showgallery.php?cat=9027&ppuser=2631&thumb=1
    do you know what gear ratio they have? if it's 4.56 $600 is a good price, but if it's 4.10 i wouldn't pay more than $500 for the d60
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I don't know what your plans are, but if I was building an off road rig I'd get those axles in a heartbeat if they were in decent shape and the rear was a D70, which were quite a bit wider WMS-to-WMS than a 14FF.
    Then you get some hummer beadlocked wheels and with thier freakish backspacing you have an almost normal truck, a little different, cheaper than most, yet totally effective.
