Dana 60 Razorback. Finished units PICS!!
Discussion in 'Vendor Forum' started by cybrfire, Jan 16, 2006.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    OK, sorry for making you guys wait a bit but wanted to get a good picture of a production unit or two. The prototype has gotten hashed over and rehashed just a few too many times.
    Front with tie rod clearance on the left.
    Rear or histeer on the right.
    All grade 8 hardware included. Locking flange bolts.:D
  2. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Nice 'n' beefy. BTW, love my 14B razor, Thanks Kert. Guess I'll have to buy the D60 cover, then I'll have no choice but to get the axle to go with it. :D
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Cool, can't wait.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    sweet! cant wait to get one.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    when thats ready, ill buy a 14b and d60 one :-)
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Couple questions. First, why does the middle fin not go all the way to the top? Second, will it clear a fat tie-rod in stock location? Third, any chance of a drain plug being offered? (Yes I am perfectly capable of installing one myself but if it came with one that would be tits).
  7. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    are the specs and price same as the 14b? i cant wait to order up all my stuff.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The middle "Razor" stops for tie rod clearance. As to the size of tie rod it will clear in factory location is still being efforted. As to the drain plug, In my Honest opinion, they are a bad idea. Not trying to tell you what you want or need, however, If your draining the fluid, its either because its dirty or has gotten moisture in it. In which case, it'd be a good time to inspect those expensive gears, lockers, and so on.
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    specs are the same as 14BFF but the price is higher by 10 bucks. 110 plus shipping.
  10. muddyblzr
    Nov 2, 2004
    623
    sounds good how long until they will be ready with the ram mount? ill keep in touch i sent ya an e-mail with a big list a few weeks back
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I just need to do a little more checking on tie rod clearance and come up with an exact number as to how large a tie rod will clear. Otherwise they are ready to go. My factory tie rod has a big kink in it so I'm gona have to address that first.
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    your going to make some with a ram mount? or at least have an option for that?
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Ready to produce
    OK, these are all finished in the R and D phase and we're ready to start some production units.
    Price is $110.00 plus the ride. Since the last pictures we have switched to a brass hex key fill plug. We also put the rest of the center razor back on just for the sake of being thorough.
    They will be available with a Ram mount option but due to the different ends available on Hydraulic rams you will need to email us to set that up. Need specs on the pin size, clevis mount or tab mount and the like. The ram mount itself will be on the cover, not a piece hanging off the side. Also if a Ram mount is requested the fill port will be moved to the opposite side of the cover to make space. Ram mounts will be a $20.00 option.
    If you need a rear cover and don't require tie rod clearance just let me know.
    All of this will be updated to the website as soon as possible. Need some better photos that what I have now.
  14. muddyblzr
    Nov 2, 2004
    623
    sounds good ill be picking up my ram and gettin my tie rod size soon. gotta love those prices! :bow: :bow:
  15. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    PM sent!!!!!!
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what size tie-rod will work with this in the stock location?
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    1.5" shouldn't be problem.
  18. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    updated again!
  19. muddyblzr
    Nov 2, 2004
    623
    do you have any pics of it with the ram mount and tie rod clearance?
    looks great always top notch work
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    nope I don't. I'll get some ASAP.
