Dana 60 rear axle Question
Discussion in 'The Garage' started by txfiremank5, Aug 27, 2004.
  1. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I picked up a free D60-FF rear today. It has 3:73's, and I can just buy a 14B for less than the cost of re-gearing it. So, my question: How much should I expect to get for it if I sell it? I know a lot of Jeep guys like 'em. I just don't know what to ask for it. /forums/images/graemlins/dunno.gif /forums/images/graemlins/1zhelp.gif
    It looks to be in good shape... just the usual dirty housing from sitting. It's been in a garage/storage so it's not real bad.
    Thanks in advance for any help or opinions..
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    well whatever you expect to pay for a 14 bolt is probably around the spot. Depending on axleshafts I guess. There is such a thing as rear 60s with really low spline count(aka weak) shafts. Pull them and check them out. 30 or 32(still not sure if there is a factory 32 spline rear) will be worth the most.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I pd #150 for my 4.56 geared Power Locked rear D 60. It depends on your market and what people want. On here with all the hub bub about 14 bolts it seems as if that D 60 is crap, when in reality it is not.
    2-$300 should be a fair price, and remember to market it to drag racers and such too.
    A Dana rear axle gives you more gearing options, while having more expensive lockers. What gears are you looking for? I have two sets of 4.10's that could be had very reasonable /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would say that 35 spline would probably be worth the most. /forums/images/graemlins/thumb.gif
  5. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Thanks for the input guys.
    /forums/images/graemlins/waytogo.gif I'll keep that in mind sub, but I'll most likely just go with a 14B. I have some propects that I'm looking at right now... ones got a detroit... (homer simpson voice)MMMMMMM (homer simson voice)
    I'll just have to see what happens.
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
  7. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Anyone know a website where i can run the numbers from the diff cover tag?
    3.73 D6TA KCA
    603716 6 L S
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    603716
    DANA 60 REAR
    Year 1977
    Make FORD
    Model F250 3/4 Ton Heavy Duty 4X2 Pick-up w/ Full-Float Axle
    Number of axle splines: 30 FULL
    DANA 60 REAR AXLE- 30 SPLINE
    (STANDARD-pinion) REAR
    Number of cover bolts: 10
    Diameter of ring gear: 9.75"
    Number of ring gear bolts: 12
    Pinion Shaft Diameter: 1.625"
    Pinion Splines : 29
    Low Case Ratio : 4.56
  9. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    You, my brother, are the MAN! /forums/images/graemlins/bow.gif
    Thanks a bunch /forums/images/graemlins/waytogo.gif
  10. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
  11. Blazer1970
    1,600
    Old Mission, MI
    Wow, twice! Seems odd that you said 3.73, and they say 4.56?
  12. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I think that's just how low the carrier will go, not the ratio, - up 4.56's. It says 3.73 on the tag.
    Twice- yeah, this firestation's computer mouse is easy to "double tap" ... /forums/images/graemlins/dunno.gif
