dana 60 rear axle
Discussion in 'The Garage' started by the general, Dec 31, 2004.
  1. the general
    the general Registered Member
    Oct 2, 2004
    96
    prinsenbeek(the Netherlands)
    is this axle a full-floater?and does it fit under my blazer?(i now GM 14 bold 10.5 is) but you can,t get an ARB locker for that axle and thats the locker i wanne have . any suggestions somebody?parts is a really dissaster in the Netherlands soo i will try and do this myself
    regards the general
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    ARB for the 14 bolt is going to be out in a matter of months.
    The Dana 60 rear in most cases is going to be 30 spline.......very weak. You don't want that crap in your truck. Leave the 14 bolt and get the ARB for that....BOMBPROOF!
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I'm runnin a d60 rear full floater,w/35 spline hardened 1.5 in shafts and a spool. and I haven't managed to break it, and I've tried!:D
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They came either way . I have seen 2 trucks with a Dana 60 rear , and jms owns one of them:xmas:
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I have a dana 60 FF rear that came stock under my GMC. It isn't very common in GM applications, but its very common in Ford, Dodge, and International pickups of the 70's.
    The 60 sf came under some light duty GM trucks (there is a discussion about this over at 67-72 chevy trucks.com right now), some Mopar muscle cars, and some Jeep pickup trucks.
    Very few 60 rears have 35 spline axles stock. If you want 14 bolt size and strength, go Dana 70.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    common under 72 older gm trucks, tons of them out there, 90% of them leaf spring and under gmc 2500 pickups
    seen more than i can remember
    they were 3.54, 4.10, and 4.56 gear under the gm trucks, and many were powrlok, you can get them for 100 each here, what i gave for the last one and it was 3.54 powrlok from a 67 2500 pickup, i know where 4 or 5 more are right now, but yeah most are not 35 spline, cept under a few applications
    if you want axle load ratings and other info on these for gm trucks then lemme know and ill dig it up
    good luck
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    To get one with the correct spring pads already on it for your 73-91 K5 you would want a Dana 60 FF rear from a 1963-72 GMC, 3/4 ton, 2wd. You will still need to move/replace the shock mounts but that part is easy.
  8. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
    new guy question
    hi Tim, what is the toughest rear, a 14 bolt? whats the second toughest, a D60?
    here's another question, what rear came in the front of 80's 3/4 ton GM trucks? The ones I've seen look like corp. 10 bolts but have 8 lugs. I was under the impression that 10 bolts only came with 6 lugs.
