Dana 60 rear FF spindle nut
Discussion in 'The Garage' started by Oxjockey, Apr 12, 2002.
  1. Oxjockey
    Oxjockey Registered Member
    Apr 12, 2002
    5
    Hey guys,
    I have a rear Dana 60 FF and the drum setup looks exactly like the scanned in manual, but for the nut tightening procedure, they say to check the Service Manual. How do I go about tightening the nut? 50 ft lbs, then back off 1/4 turn and stake it?
    Thanks!
    Bryan
  2. Oxjockey
    Apr 12, 2002
    5
    BTT? TIA
  3. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    If you can't find the exact spec, I would think the normal tighten it until the hubs starts to turn hard and then back it off a little, would work. You will probably want a little resistance in the hub spinning. Once the bearing seat all the way in it should be spot on. This is just a suggestion to get ya going. Im sure someone will chime in with the correct torque/procedure.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    zero preload like all the other ff rear axles that run in gear oil is where i would set it
