dana 60 rear u-joint help please........
Discussion in 'The Garage' started by bigbadchev84, May 1, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i am swapping out my brothers rear end for a 1967 gmc dana 60 with 4.56 gears tomorrow, we have already relocated the spring perches and the shock mounts but my question is the u-joint, im not sure what is in there now, but his old rear end is a 77' 14bolt with 4.10s i know it is a down grade but he is going to re-gear the 14bolt when he gets some money to spare.....anyone have a part number or any helpful info?
  2. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    It's going to be either a 1350 or 1410 u-joint. Measure across the the yoke on each axle. If they are the same, yours should bolt up.
    What drive shaft are you using on the rig? Stock 3/4 ton? Or a 1/2 ton w/ a conversion joint?
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    stock 3/4 ton.....i didnt have a measuring tape in the shop so i was hoping someone could help me out....im heading to napa now to see what i can find...
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The Neapco catalog says 1310 for 3spd trans (auto or stick) and 1350 for 4spd trans.
    (Assuming '67 GM 3/4-ton 2wd pickup).
  6. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    it was a 4x4, it looks to be the same u-joint... thanks for the help
