Dana 60 rear with factory disk brakes, traclok $800obo
Discussion in 'General Parts for Sale' started by Trevor, Oct 21, 2003.
  1. Trevor
    Trevor 1/2 ton status
    Mar 10, 2002
    160
    Auburn, Ca
    I just picked up a 99 Ford van dana 60 rear. The BOM # is 606190-2. It has 3.54 with a factory trac-lok. The axle shafts are the big diameter, but I think they are 33 spline. It is 68" and standard 8 lug pattern. It is not a c-clip or semi floater. It is a Full Floater. Would be perfect width to match a 60 front. Front yoke is flat 4 bolt flange to accept driveline. Has a speed sensor in the center section. Asking $800 obo. For a little more, would consider putting 3.73, 4.10, or 4.30 if interested. Located in Auburn Ca. If interested, I can e-mail pictures.
  2. Trevor
    Mar 10, 2002
    160
    Auburn, Ca
    I just pulled the axle shaft and checked it out. It is 32 spline. I put it next to a 14 bolt axle and measured it with my calipers. It is actually bigger than the 14 bolt axle. The 60 measures 1.370" in diameter and the 14 bolt measures 1.345" in diameter.
