Dana 60 rearends from Ford or Dodge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan88Jimmy, Jan 13, 2001.
  1. Ryan88Jimmy
    Ryan88Jimmy Registered Member
    64
    Winnipeg, Manitoba, Canada
    What needs to be done in order to bolt up a ford or dodge dana 60 rear end to my 88 jimmy? Is the only difference the spring perches?
    Ryan88Jimmy
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Perches, u-joints, and brake fittings. Double check your shock mounting locations too.
  3. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    Gotta be careful when ya go Dana 60 rear. Alot of the early 60's were coarse splined units and won't be much stronger than what you have. Try for later models an still check. Real easy on a full floater to just undo the axle bolts on the hub and slide out the axle to be sure they are 35 spline. Other than that probably perches and shock mounts. I like the 3/4 ton 14 bolt because it's basically a bolt on. New u-bolts and you are in there. Of course re-locate the shock mounts. 60's are cool though.
    "You're right... I don't understand that Jeep thing!"
