Dana 60 reassembly help
Discussion in 'The Garage' started by eldon519, Jun 22, 2003.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    Kennesaw, Georgia
    Hey, I recently took apart my D60 hubs to install 35 spline stubs and I'm about to put it back together but thought maybe I should reapply some grease to the bearings and such. I've got an NLGI #2 Grade Lithium based grease. Can I use it to reassemble the hubs or do I need a special grease? It says this will work for disc brake wheel bearings but I wanted to make sure mixing the greases wouldn't be a problem. THanks, Cory
  2. thatK30guy
    Jan 12, 2001
    If it don't read "high temperature" anywhere on the tube, I wouldn't use it as wheel bearings are subjected to pretty high temps when they are spinning in there.
