Dana 60 Rebuiders: Did you keep your Outer Oil/Mud Slinger or get rid of it?
Discussion in 'The Garage' started by MuddinManny, Jan 7, 2007.
  1. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey Y'all,
    For those who rebuilt their Dana 60's, did you keep/replace your outer shaft oil/mud slingers or did you discard them? How much functionality do these actually have? They wouldn't be there if they didn't serve a purpose but they're such a PITA to find. I found the slinger, but not the corresponding seals that go with them. A little help would be appreciated.
    Thanks!
    Manny
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i kept mine no problems finding them, got them from a dana supply house here in town.
    i thought mini-wally said ORD had them??
  3. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Mine unfortuately, are completely destroyed. Rust took its toll.
    I checked their web site for them as I just recently placed an order with ORD They list/have every type and kind of bearing, race and seal for the 60, but don't list those. Strange??? Either way, those slingers' are tough boogers to find. At least the matching seals anyway.
    Manny
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You must use the "slinger" as that is where the seal goes on and without it or the seal you are going to ruin bearing after bearing on that D60.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have mine installed. I think they are called a stone shield to keep big stuff out of the spindle bearing. I do not however have the snap ring on the shaft to keep it pulled tight against the seal. I dont run mud or water so I dont think it is an issue for me. As for where to get them I got mine on Ebay for cheap I will see if I can find them they were in a e-store. Partsmike also has them.
    Ira
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Ira, i would be careful not running the snap-rings on your stubs as i've heard stories of the axle binding up when in a turn and exploding the u-joint and or shaft.
  7. sandawgk5
    Oct 28, 2003
    6,881
    Maybe that is why I broke my front Dshaft yoke:doah:. Where can I find the proper snap rings?
    Manny- I will get in the garage and see if I still have the other set of slingers if I do I will let you know. How soon do you need them?
    Ira
  8. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Guys,
    I must be having the worst case of a [​IMG] I've ever had. It is my understanding that the spindle has a needle bearing, an inner seal that sits against that bearing, and an outer shield that is pressed into the bearing that holds it all together. Next comes the oil slinger which sits up by the drive shaft yoke base and has a seal that "locks" it snug in place.
    This is where the [​IMG] comes in. I'm looking at the following pic from Partsmike. What am I missing...
    This is the seal kit from them:
    Are any of these the slinger or are they all the spindles???
    Now I'm completely lost. This is so stupid. Why can't I understand this easy concept. I'm such a [​IMG]
    Manny
  9. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
  11. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
  12. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    No.. i dont think it does..it just says lips seals and spindle bearing.. i think it is the same kit as the picture you posted from partsmike.net..
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you ordered the SBK3 kit it does not come in the kit. You will still need to buy them.
  14. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Thanks guys! I appreciate it. Y'all are just as much a part of this projects success as anyone. I'm very grateful.
    Manny
  15. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
  16. sandawgk5
    Oct 28, 2003
    6,881
    Nope just slide them over the stub and tap down with a hammer so they are seated against the yoke. You should see a little ledge on your stub where it will seat. Maybe 15 min for both sides since you are already torn down:D . I guess I wont look through the garage then:bow: .
    Ira
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    I posted this number on Manny's build-up thread last week.
    I also quoted that the SBK-kits are optional with the slingers. SBK1 and SBK3 are the common replacement kits for seals and bearing. There's another number with SBK that has the slingers in them, too. Don't know what they are but can find out.
  18. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    I saw that you posted the kits K30, but I bought all the bearings, races and seals. I just needed the slingers. I don't know why, but here in Texas, they have no clue what they are. In fact, most have never heard of a Dana 60 before. They still require the VIN, year, make and model. Go figure! Hope you didn't take it personally. No offense meant.
    Manny
