Dana 60 seal
Discussion in 'The Garage' started by stockk5, Feb 7, 2006.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Hey everyone, my Dana 60 rear axle is leaking outta the pinion seal.. how do i go about changing this? seems a lil scary and complex. Any tips? write ups anywhere? thanks
  2. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    is this a real hard job to do?
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Remove the yoke, remove seal, lube new seal, reinstall yoke and new pinion nut. Dana 60s use shims on the pinion so they are actually easier than GM axles.
    Ira
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    oh ok so its not like a big job where i'd have to have my pinion and all that stuff re-set up like im putting new gears in right?
  5. sandawgk5
    Oct 28, 2003
    6,881
    Correct, the pinion shims are between the inner bearing and the pinion head. Therefore when you install the new nut and torque it to spec it will reset the pinion preload to were it is supposed to be.
    Ira
