Dana 60 set up help!
Discussion in 'The Garage' started by JpEater, Sep 9, 2006.
  1. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    I have a Dana 60 front with a 4.10 gear and open carrier. I ordered an E-Locker to fit. The box said 4.10 and down on it. My problem is that the ring gear hits the pinion so the carrier won't go in. I put a bearing and race on the RG side of the carrier and put a straight edge on the race and measured to the RG mounting surface of each carrier. On the open carrier it is 2 1/4 inches and on the E locker it is 2 3/8. THat is putting my ring gear 1/8" too close to the pinion. How can I figure out if I have the wrong E-Locker or not because it appears as it is wrong. The only number engraged on the locker is 04A251-002. THanks
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    The difference in carriers is .100" so you have the wrong one.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Are you sure the ring gear is seated all the way on the locker?
  4. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    Yep the ring gear is seated good. Can I buy a 4.10 gear to fit this carrier? I am trying to get this and many other things done to make it to Blazer Bash so I don't have enough time to try to send it back and get another.
  5. 6.2puller
    Jul 8, 2004
    569
    New England
    Nope, you can get thick gears for the high numerical carrier but not thin gears for the low numerical carrier
  6. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    So clarify this for me please... If I have the thick version E-Locker does that mean that it is for 4.56 and numericaly up gears?
  7. 6.2puller
    Jul 8, 2004
    569
    New England
    Yes sir. When the pinion gets tinny on the "lower" (numerically higher) gears they move the ring gear mounting flange .100 closser to the pinion so that the ring gear isn't 3" thick and weighing 20#s. You can get thick cut gears that are that extra .100" to run say 5.13s on a 4.10 and taller (numerically lower) carrier but you cant fit a 4.10 set on the carrier that is .100 closer to the pinion cause their is not room.
  8. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    Thanks for the help.
