Dana 60 shaft stub length
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, May 16, 2002.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Any difference in the stub shaft length in dually and SRW Dana 60s? Also what is the dia. of the bearing hub? TIA
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    There is no difference in the stub shaft length from DRW to SRW. The only difference is the bearing hub itself.
    The dia. of a SRW hub on the outboard end (at the locking hub) is 4 1/4". It has a slight taper, the dia on the hub at the outboard surface of the rotor is 4 1/2".
    This applies to Chevy 60's only, Dodge bearing hubs are different (don't know about stub length) and all of the Ford stuff is shorter (bearing hub, axle & spindle).
    Hope this helps.
