dana 60 spring perch bolt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 27, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You know hwo two bolts thread into the dana 60 housing instead of using a ubolt?
    I need longer bolts. I only have Procomp 6" lift springs, but I guess they're thicker.
    Should I buy them from 4WPW or just go to the hardward store? Gr 5 or gr 8? I'd imagine gr 8 for the shearing strength.
    And what do I torque those to? The idea of stripping the threads in my housing is unpleasant. SHould I use some loctite?
    -- Mike
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Go to the hardware store and buy some grade 8 bolts, don't use loctite.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> On a related note, what is the thread size of them there bolts? </font color>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get some grade 8's, and they are a 5/8" bolt in coarse thread. /forums/images/graemlins/thumb.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you used studs and thread them to the bottom of the holes you will not pull the threads from the casting.
    why use bolts?
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i agree with mj use some grade 8 studes not bolts /forums/images/graemlins/thumb.gif
  7. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I know spring dimensions will have some effect on your answer but, in general what length bolts or studs should be used?
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    I forgot about studs. These would be the absolute best stuff to use instead of bolts.
    Like m_j said, use studs to have them thread all the way down into the holes and they will be stronger than bolts.
    The length to use will depend entirely up to the spring pack thickness, whether you are using ORD zero-rates, etc. etc.
    Best to get the springs on the truck and sitting on the axles and then measure for the length of studs/bolts you need. /forums/images/graemlins/wink.gif
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Anybody have a good source for grade 8 studs and maybe some staked nuts for them? </font color>
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Superlift has them. They are about the only aftermarket lift company I know of that has and sells them. /forums/images/graemlins/thumb.gif
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, I called Superlift, they have a kit that has studs and u-bolts, but it won't work with the zero rates that are going into my truck. I know that someone posted the name of a big industrial supplier along the lines of Grainger or McMaster-Carr awhile back, but these guys had alot more fasteners. I think it may have been Rene that posted it. Anybody? Beuller? /forums/images/graemlins/1zhelp.gif </font color>
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    What do you mean they won't work with the zero-rates? Not long enough studs? They sure seem long enough to me as I've seen a few pics of them on D60's and there were ample threads sticking above the nuts that showed enough room for the zero-rates to fit in perfectly.
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I dunno, I called Superlift and the guy said that they wouldn't work. Will, it's really no matter now anyways, since it seems that one of the holes on my D60 was stripped at some point and was tapped to 3/4". So, now I need to find a 3/4" stud... /forums/images/graemlins/crazy.gif </font color>
  14. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
  15. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Any idea what to torque them to?
    -- Mike
