Dana 60 spring perch
Discussion in 'The Garage' started by highrlr, Jun 13, 2005.
  1. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Where can i buy the driver side front spring perch? The Dana 60 i bought has a bent perch and I was going to try and cut it and bend it back and weld it back together but I figure a new perch would just be better and easier.
  2. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    take 1 section about 5" long of 2.5x2.5 square tube 1/4 thick. cap ends off. and cut arch in tube and then put center pin hole in the top. this will be stronger than any stock perch. kind of like this one.
  3. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thanks for the idea, that is probably what I will do since I have still not been able to find a stock replacement.
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    got a pic of the way i did mine for ya. not ready to weld them on yet as the axle is bad and i need to swap the new one from a van under. but this showes you how to do it.
