Dana 60 Spring Perch
Discussion in 'The Garage' started by kwissman, Jun 23, 2006.
  1. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    I am going to pick up a d60 and 14Bff this weekend. The guy said that the spring perch on the D60 would have to be moved since it was on the bottom to use in a spring under jeep. Is the spring perch on the DS of the D60 the same as a 14Bff.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    The perches will still be there on the pumpkin, that isn't easily removed. The pass side is just welded on, so that will be easy to replace. The perches might not be the same, as the tubes are different diameters.
