Dana 60 still wobbly 42" tire
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bgwhlr, Aug 21, 2003.
  1. bgwhlr
    bgwhlr Registered Member
    Feb 18, 2003
    14
    Tigard, OR
    Dana 60 still wobbly 42\" tire
    Hey just wonderin if anybody else had problems with the kingpins in the dana 60. I replaced all nylon bushings, bearings, and races and the bottom plate with the post the bearing rides on. It fixed the passenger side, but the bottom of the drivers still moves. The tire wobbles at about 35 mph, and gets scary at 55mph. Help, everything went in tight. the only thing not replaced was the spring, and they were still strong it seemed. /forums/images/graemlins/1zhelp.gif
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Re: Dana 60 still wobbly 42\" tire
    do a search for DEATH WOBBLE and REPLACE the spring .
  3. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    seems I had the same problem with my Dodge cummins truck. I think the shop added shims under the cap to preload the bushing more. That or I got it all wrong......
  4. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    Um, could it be a worn out steering damper???
