Dana 60 Stubs
Discussion in 'The Garage' started by txfireman110, Feb 26, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I keep hearing about the 35 spline upgrade for D60s. Just how weak are the stock 30 spline stubs? /forums/images/graemlins/thinking.gif Compared to a 10 bolt or D44??? Just wondering if I should expect to break the 30 splines right away or what?
    Thanks /forums/images/graemlins/peace.gif
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    they are like anything else it depends on how u ride. i say they are a lot stronger than a 44 or 10 bolt.
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    If you run those 33's you have listed in your Bio I would say you will be fine and dandy. The 30 spline stubs are good up to about a 36" tire and that's not saying they are bullet proof. Any tire much bigger and you are on a short fuse before /forums/images/graemlins/angryfire.gif
  4. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    the stock 30 spline stubs off a d60 are the same as d44 except the hole for the u-joints are bigger. they are definately a weak link.
  6. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i broke mine with i believe my 37's, or 40's with street driving, i dont really know when it broke, but it did. I havent wheeled with the 40's yet and it was already broken, which makes me think the 37;s did it /forums/images/graemlins/yikes.gif
  7. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    NO THEY MOST CERTAINLY ARE NOT!!! /forums/images/graemlins/ooo.gif The dana 44/10 bolt has a 30 spline INNER shaft, but the outer is not 30 spline. The dana 60 30 spline stub is much bigger than the dana 44/10 bolt STUB axle.
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yes a 30 slpine stub is the weakest part of a D60. The 19 spline stub of a D44 is supposed to be it's weakest part. It takes a lot of work to blow a 30 slpine stub with 38's or less. You can run the 30 sline, see how it works. Carry an extra stub , u-joint, spindle, and locking hub just in case you do kill it. The D60 bible goes to explain that the neck down inners are weaker than a 30 spline outter as well. Depending on which shafts you have that is a lot to change out for a might break part. Plus it is funner to break a part you already wanted to replace so if a question comes up you can say "ya I broke one and then..."
    My .02 /forums/images/graemlins/thinking.gif
