Dana 60 swap questions...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Apr 29, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK.. i am trying to get a dana 60...
    What is needed to do the dana 60 swap.. from a 3/4 ton dana 44...
    No crossover steering... not yet...
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Bolt it in. Might need new brake lines due to the banjo fitting on the caliper being different.............good time to go to stainless braided (ORD sold me mine). Front u-joint should be the same, but if truck is not lifted (sorry, forgot to check your bio) be careful your front driveshaft is not too compressed now, because the D60 has a longer snout/yoke than your D44. You'll need new u-bolts, ORD provided mine. Make sure you get the spring pads with the D60. The drag link will need to be adjusted about an inch, but no biggie. Any other questions, let us know..........It's a really simple swap.
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Right about now I would settle for a 3/4 ton D44 since I CAN"T seem to find a D60. Would you just send me your D44 since you don't need it now ;-)
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If you are currently running a raised steering arm, you will have to get either a drop drag link or steering block for the 60 because the boomerang style steering arm will not work. I would recommend going straight to crossover. Avoid the crappy in between setup. ORD, Skyjacker, and others can provide the u-bolt and stud combo that you need to hang your 60. The D60 pinion is longer than the D44, make sure your driveshaft has enough compression. My Skyjacker braided stainless brake lines bolted right up to the D60. You will also need wheels to clear the brakes. 15's with 2 1/2" backspacing will work as well as 16 or larger.
