dana 60 swap?
Discussion in 'The Garage' started by Bhintz, May 12, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    if I have after market extend brake lines for a 10 bolt will they work on a dana 60 or do I need new ones
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    they should mine did. it depends on whether the calipers u have & the calipers on the 60 are both metric or both standard bolts.
    i honestly think it will work even if they are mix matched.
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Dana 60's use the same size banjo bolt as 10 bolts. They are metric. 10 mm if I remember correctly.
