Dana 60 Swap
Discussion in 'The Garage' started by Gmck2500mudder, Aug 14, 2006.
  1. Gmck2500mudder
    Gmck2500mudder Registered Member
    Jul 21, 2006
    31
    Canada
    Hi,
    I am about to swap my old dana 44 for a dana 60. I this a hard swp to do? Is there anything in particular I should know before i do this? Any help tips or links would be awsome. Thanks a lot.
    Clayton
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    The brakes lines have to be replaced and you will need new banjo bolts as well. New u-bolts (3), make sure your 60 has the studs for the spring plate on the passenger side. You will also need spring plates. That's all I can think of, its pretty much bolt in after that!
  3. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    depends on what the axle came from and what its going into. Later Blazers(78+) should have 10mm banjo bolts so 95% of the D60 calipers bolt right up. But if you get a 77 D60 like i did, it'll have 7/16" banjo bolts like the earlier blazers, and be bolt it for 73-77.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    dont forget steering! its best to go ahead and piece together a crossover setup
