Dana 60 Tie Rod
Discussion in 'Parts & Trucks Wanted' started by K30CJ, Apr 11, 2004.
  1. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    Anyone have a good Dana 60 tie rod? The end that does not have the threaded end that you can replace is loose on my crew cab. Maybe someone has removed a good one to change to high steer or hydraulic? I'll check Monday what a new one costs, but thought I'd check here too.
  2. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I pulled my tie rods and sleeve off about a week ago. I'm not sure how good any of it is. Which part are you looking for? Drivers side tie rod (long with hole for stabilizer), passenger side tie rod (short) or sleeve? Both tie rod ends are threaded, they fit into the sleeve.
    Eric M.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I were you I'd throw it away and buy a rock rod or something. They're cheap and have replacable ends.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Sent you a PM.
  5. K30CJ
    May 16, 2003
    429
    IN
    Eric M.
    The driver's side, long end with hole for stabilizer. The rod end is worn and loose.
